Material Comparison Guide
Choose from hundreds of manufacturing materials including multiple grades of thermoplastics, metals, and elastomers.
When selecting a material, consider the mechanical properties, manufacturability characteristics, cosmetic appearance, and cost. If you choose to supply your own material for injection molding, please complete this customer-supplied material form, which requires you to upload MSDS and process data sheet documents. We will contact you with shipping information and a material ID number once your information has been processed. For milling and turning dimensions by material, please see maximum part extents for machining.
Material Material Category Attributes Tensile Strength Impact Strength Heat Deflection Durometer Elongation at Break Elongation Hardness Tear Strength Manufacturing Process
ABS Plastic
  • Cosmetic appearance
  • Dimensional stability
  • Impact resistance
5,000-12,000 psi 3-7.5 ft-lb/in 140-200°F 20-30% Injection Molding
ABS CNC Milling
ABS Flame Retardant CNC Milling
Polylac PA-746 Data Sheet Injection Molding
Polylac PA-765 Data Sheet Injection Molding
Cycolac MG47 Data Sheet Injection Molding
Lustran 433 Data Sheet Injection Molding
Lustran PG 298 Data Sheet Injection Molding
Lustran 348 Data Sheet Injection Molding
RTP 605 Data Sheet Injection Molding
ABS-Like Plastic
  • Accuracy
  • Durability
  • Impact resistance
5.7-7.8 ksi 0.79-0.91 ft-lb/in 115-138°F 6.1-20% 3D Printing
ABS-Like Stereolithography
Huntsman RenShape 7820 Data Sheet Stereolithography
MicroFine Green Data Sheet Stereolithography
Somos WaterShed XC 11122 Data Sheet Stereolithography
ABS/PC Plastic
  • Impact resistance
6,400-18,000 psi 8-12 ft-lb/in 140-210°F 40-50% Injection Molding
Bayblend FR 110 Injection Molding
Bayblend FR 3010 Data Sheet Injection Molding
Bayblend T85 XF Data Sheet Injection Molding
Bayblend T65 XF Data Sheet Injection Molding
Cycoloy C6600 Data Sheet Injection Molding
Cycoloy C2950 Data Sheet Injection Molding
Aluminum Metal
  • Corrosion resistance
  • High strength-to-weight ratio
  • Temperature resistance
38-83 ksi 1-17% 55-87 HRB CNC Machining
Aluminum 6061-T651 CNC Milling
CNC Turning
Aluminum 7075-T651 CNC Milling
CNC Turning
Aluminum AlSi10Mg Data Sheet Direct Metal Laser Sintering
Metal Plating Data Sheet Stereolithography
Brass Metal
  • Chemical resistance
  • Ductility
  • Strength
45-61 ksi 23-25% 32-36 HRB CNC Machining
Brass 260 CNC Milling
Brass C360 CNC Turning
Cobalt Chrome Metal
  • Biocompatability
130 ksi 20% 25 HRC 3D Printing
Cobalt Chrome Data Sheet Direct Metal Laser Sintering
Copper Metal
  • Electrical conductivity
29-52 ksi 5-50% 40-110 HV CNC Machining
Copper C101 CNC Milling
CPVC Plastic
  • Flame resistance
7,300 psi 9 ft-lb/in 198°F 27% CNC Machining
CPVC CNC Milling
Digital Photopolymer Elastomer / Silcone Rubber
  • Durability
  • Flexibility
  • Transparency
30-95 shore A, Rigid 200-270% 5-30 kg/cm 3D Printing
Digital Clear Data Sheet Polyjet
Digital White Data Sheet Polyjet
Digital Black Data Sheet Polyjet
ETPU Plastic
  • Crack resistance
  • Durability
  • Impact resistance
10,000 psi 10 ft-lb/in 280°F 90% Injection Molding
Isoplast 202EZ Data Sheet Injection Molding
HDPE Plastic
  • Durability
  • Impact resistant
  • Stiffness
2,900-4,500 psi 80 ft-lb/in² 130-250°F 350-950% Injection Molding
HDPE CNC Milling
Unipol DMDA 8007 Data Sheet Injection Molding
Marlex 9006 HID Data Sheet Injection Molding
Inconel Metal
  • High strength
  • Excellent temperature and corrosion resistance
  • Good tensile, fatigue, creep and rupture strength
180 ksi 12% 35 HRC 3D Printing
Inconel 718 Data Sheet Direct Metal Laser Sintering
LCP Plastic
  • Strength
12,000-32,000 psi 10 ft-lb/in 525°F 1.6% Injection Molding
Vectra E130 Data Sheet Injection Molding
LDPE Plastic
  • Crack resistance
  • Flexibility
  • Impact resistance
1,200-4,000 psi 130 ft-lb/in² 130-190°F 400-500% Injection Molding
Dow LDPE 722 Data Sheet Injection Molding
LDPE CNC Milling
LLDPE Plastic
  • Flexibility
1,400 psi 190 ft-lb/in 190°F 600% Injection Molding
Dowlex 2517 Data Sheet Injection Molding
Low Carbon Steel Metal
  • Soft
64 ksi 15% 69 HRB CNC Machining
Steel CR 1018 CNC Milling
CNC Turning
LSR Elastomer / Silcone Rubber
  • Durability
  • Flexibility
30-70 shore A 290-620% 21-33 N/mm Injection Molding
Elastosil 3003/30 A/B Data Sheet Injection Molding
Elastosil 3003/40 A/B Data Sheet Injection Molding
Elastosil 3003/50 A/B Data Sheet Injection Molding
Elastosil 3003/60 A/B Data Sheet Injection Molding
Elastosil 3003/70 A/B Data Sheet Injection Molding
LSR (Fluorosilicone) Elastomer / Silcone Rubber
  • Fuel and oil resistance
  • Suitable for fluids
60 shore A 220% 14 N/mm Injection Molding
Silastic FL 60-9201 Data Sheet Injection Molding
LSR (Medical) Elastomer / Silcone Rubber
  • Biocompatability
  • Transparency
50 shore A 499% 47.4-52.4 kN/m Injection Molding
Dow Corning QP1-250 Data Sheet Injection Molding
LSR (Optical) Elastomer / Silcone Rubber
  • Biocompatability
  • Optical clarity
72 shore A 80% Injection Molding
Dow Corning MS-1002 Data Sheet Injection Molding
Magnesium Metal
  • Weight reduction
34.8 ksi 10% CNC Machining
Magnesium AZ31 CNC Milling
PA (Nylon) Plastic
  • Rigidity
  • Strength
6,000-29,000 psi 2-8 ft-lb/in 180-350°F 10-60% Injection Molding
Nylon 6 CNC Milling
DuraForm HST Composite (Nylon 12) Data Sheet Selective Laser Sintering
PA 614-GS (Nylon 12) Data Sheet Selective Laser Sintering
PA 850 Black (Nylon 11) Data Sheet Selective Laser Sintering
ALM PA 650 (Nylon 12) Data Sheet Selective Laser Sintering
Nylon 12 (HP 3D Printing) Data Sheet Multi Jet Fusion
Zytel 73G15L (15% glass-fiber Nylon 6) Injection Molding
Zytel 77G33L (33% glass-fiber Nylon 6/12) Injection Molding
Zytel 101 L (Nylon 66) Injection Molding
Zytel 103 HSL (Nylon 66) Injection Molding
Zytel 70G13 HS1L (13% glass-fiber Nylon 66) Injection Molding
Zytel 8018 HS (14% glass-fiber Nylon 66) Injection Molding
Zytel 80G14AHS (14% glass-fiber Nylon 66) Injection Molding
Zytel 70G33 HS1L (33% glass-fiber Nylon 66) Injection Molding
Zytel ST-801 (impact modifier, rubber Nylon 66) Injection Molding
Zytel HTN 51G35HSL (35% glass fiber Nylon) Injection Molding
Hylon Select N1000EHL (Nylon 66) Data Sheet Injection Molding
Hylon Select N1013HL (13% glass-fiber Nylon 66) Data Sheet Injection Molding
Hylon Select N1033HL (33% glass-fiber Nylon 66) Data Sheet Injection Molding
RTP 200 UV (Nylon 66) Data Sheet Injection Molding
RTP 203 FR (20% glass-fiber Nylon 66) Data Sheet Injection Molding
Vydyne R533H (33% glass-fiber Nylon 66) Data Sheet Injection Molding
Minlon 10B40 (40% mineral-reinforced Nylon 66) Injection Molding
Nylon 6/6 CNC Milling
Nylon 6/6 (30% GF) CNC Milling
PBT Plastic
  • Low moisture absorption
6,000-17,500 psi 1-3 ft-lb/in 200-420°F 2-50% Injection Molding
Valox 357 Data Sheet Injection Molding
Valox 420SEO Data Sheet Injection Molding
Crastin S600F20 Injection Molding
Polycarbonate (PC) Plastic
  • Impact resistance
9,000-23,000 psi 2-18 ft-lb/in 150-300°F 5-120% Injection Molding
Polycarbonate CNC Milling
Polycarbonate (20% GF) CNC Milling
Lexan 940 Data Sheet Injection Molding
Lexan HP1-1H112 Data Sheet Injection Molding
Lexan HP1-112 Data Sheet Injection Molding
Lexan 3412R-131 (20% glass-fiber PC) Data Sheet Injection Molding
Makrolon 2405 Data Sheet Injection Molding
Makrolon RX2530 Data Sheet Injection Molding
Makrolon 2458 Data Sheet Injection Molding
Makrolon 2407 Data Sheet Injection Molding
Hylex P1025L Data Sheet Injection Molding
RTP 399X71833 Injection Molding
RTP 301 (10% glass-fiber PC) Data Sheet Injection Molding
PC-Like Plastic
  • Accuracy
  • Stiffness
  • Temperature tolerance
6.8-11.6 ksi 118-506°F 0.7-13% 3D Printing
3D Systems Accura 5530 Data Sheet Stereolithography
Somos PerFORM Data Sheet Stereolithography
3D Systems Accura 60 Data Sheet Stereolithography
PC/PBT Plastic
  • Impact resistance
6,300 psi 17 ft-lb/in 210°F 3-120% Injection Molding
Xenoy 6620 Data Sheet Injection Molding
PEEK Plastic
  • Sterilizability
  • Stiffness
  • Strength
13,000-30,000 psi 3.5-4.5 ft-lb/in 300-625°F 40-50% Injection Molding
PEEK CNC Milling
Victrex 450G Data Sheet Injection Molding
PEI (Ultem) Plastic
  • Heat resistance
  • Impact resistance
  • Strength
14,000-28,000 psi 1-2 ft-lb/in 350-420°F 4-60% Injection Molding
PEI (Ultem) CNC Milling
RTP 2100 LF Data Sheet Injection Molding
Ultem 1000 CNC Milling
Ultem 2300 (30% glass-filled) CNC Milling
PET Plastic
  • Stiffness
  • Strength
7,000-23,000 psi 0.5-8 ft-lb/in 250-470°F 1-45% Injection Molding
PET CNC Milling
Rynite 530 (30% glass-fiber) Injection Molding
Rynite 935 (35% glass-mica low-warp) Injection Molding
PETG Plastic
  • Durability
  • Transparency
7,250 psi 3 ft-lb/in 185°F 100-130% Injection Molding
Eastar 6763 Data Sheet Injection Molding
PMMA (Acrylic) Plastic
  • Optical clarity
  • Rigidity
2,800-13,000 psi 0.25-1 ft-lb/in 180-215°F 3-7% Injection Molding
PMMA (Acrylic) CNC Milling
Plexiglas V825 Data Sheet Injection Molding
POM (Acetal/Delrin) Plastic
6,000-22,000 psi 0.75-2 ft-lb/in 180-300°F 10-40% Injection Molding
POM (Acetal/Delrin) CNC Milling
RTP 800 GB 10 (10% glass-bead acetal) Data Sheet Injection Molding
RTP 800 GB 20 (20% glass-bead acetal) Data Sheet Injection Molding
Celcon M90 Data Sheet Injection Molding
Acetal Homopolymer (Delrin 150) CNC Milling
Delrin 500P Injection Molding
Acetal 20% Glass filled (Delrin 570) CNC Milling
Acetal Copolymer CNC Milling
Acetal Static Dissipative (Tecaform SD) CNC Milling
PP Plastic
  • Solvent resistance
3,900-18,500 psi 0.5-5.5 ft-lb/in 120-300°F 10-230% Injection Molding
RTP Anti-static Permastat 100 Data Sheet Injection Molding
Maxxam FR PP 301 Injection Molding
Profax 6323 Data Sheet Injection Molding
Profax 6523 Data Sheet Injection Molding
Profax PD702 Data Sheet Injection Molding
Profax SG-702 Data Sheet Injection Molding
FHR PP P5M6-048 Injection Molding
PP (Polypropylene Homopolymer) CNC Milling
PP (Polypropylene Copolymer) CNC Milling
PPE/PS Plastic
8,500 psi 2.5-8 ft-lb/in 250-280°F 15-30% Injection Molding
PPE/PS CNC Milling
Noryl 265 CNC Milling
Noryl 731-701 Data Sheet Injection Molding
PP-Like Plastic
  • Accuracy
  • Durability
  • Flexibility
4.4-4.7 ksi 0.9-1.0 ft-lb/in 120-300°F 15-20% 3D Printing
PP-Like Stereolithography
Xtreme White 200 Data Sheet Stereolithography
DSM Somos 9120 Data Sheet Stereolithography
PPS Plastic
14,000-28,000 psi 0.5-6 ft-lb/in 400-500°F 1-2% Injection Molding
Ryton R-4-02 (40% glass-fiber) Data Sheet Injection Molding
Ryton R-4 (40% glass-fiber) Data Sheet Injection Molding
Fortron 1140L4 (40% GF) Data Sheet Injection Molding
PPSU Plastic
  • Flame resistance
  • Impact resistance
10,100 psi 13 ft-lb/in 428°F 40-120% CNC Machining
PPSU CNC Milling
Radel R 5500 CNC Milling
PS Plastic
  • Impact resistance
  • Stiffness
4,200-11,000 psi 0.25-7 ft-lb/in 185-190°F 3-30% Injection Molding
Styron 666D Data Sheet Injection Molding
Styron 498 Data Sheet Injection Molding
PSU Plastic
  • Mineral resistance
  • Sterilizability
  • Strength
9,500-18,000 psi 0.5-7 ft-lb/in 300-350°F 50-100% Injection Molding
Udel P-3703 NT 11 Data Sheet Injection Molding
PTFE (Teflon) Plastic
  • Flame resistance
2,900-5,000 psi 2-6 ft-lb/in 500°F 210-400% CNC Machining
PTFE (Teflon) CNC Milling
PVC Plastic
  • Flame resistance
7,800 psi 0.8 ft-lb/in 162-172° F 150% CNC Machining
PVC CNC Milling
SB Plastic
  • Stiffness
  • Transparency
  • Warp resistance
4,850 psi 0.5-1 ft-lb/in 150-160° F 30% Injection Molding
K-Resin SBC KR01 Data Sheet Injection Molding
Stainless Steel Metal
  • Crack resistance
66-210 ksi 5-56% 35-101 HRC CNC Machining
Stainless Steel 17-4 PH Data Sheet Direct Metal Laser Sintering
Stainless Steel 304/304L CNC Milling
CNC Turning
Stainless Steel 316/316L CNC Milling
CNC Turning
Stainless Steel 316L Data Sheet Direct Metal Laser Sintering
Steel Alloy Metal
  • Durability
  • Strength
95 ksi 25% 92 HRB CNC Machining
Steel Alloy 4140 CNC Milling
CNC Turning
Titanium Metal
  • Strength
  • Weight reduction
80-140 ksi 10-20% 30-39 HRC CNC Machining
Titanium Ti 6-4 Data Sheet Direct Metal Laser Sintering
TPE/TPV Plastic
  • Flexibility
35-87 shore A 330-610% 10-52 kN/m Injection Molding
Santoprene 111-45 Data Sheet Injection Molding
Santoprene 101-64 Data Sheet Injection Molding
Santoprene 211-45 Data Sheet Injection Molding
Santoprene 251-70W232 Data Sheet Injection Molding
Santoprene 101-87 Data Sheet Injection Molding
Santoprene 111-35 Data Sheet Injection Molding
Santoprene 101-55 Data Sheet Injection Molding
Santoprene 101-73 Data Sheet Injection Molding
Santoprene 201-87 Data Sheet Injection Molding
Hytrel 3078 Injection Molding
Versaflex 6240-1 Data Sheet Injection Molding
Versaflex 6258-1 Data Sheet Injection Molding
Versaflex 1040X-1 Data Sheet Injection Molding
TPU Plastic
  • Abrasion resistance
  • Flexibility
  • Impact resistance
83 shore A-43 shore D 200-670% 87-123 kN/m Injection Molding
TPU-70A Data Sheet Selective Laser Sintering
Texin 245 Data Sheet Injection Molding
Texin 983 Injection Molding
UHMW Plastic
  • Durability
  • Flexibility
5,800 psi 116°F 300% CNC Machining
UHMW CNC Milling
Quadrant EPP Tivar 1000 CNC Milling
Plastic
Bright White
Product #UN0005
Bright White (for PC)
Product #NCO3642532
Sno White
Product #348-012002
Reedlite (for PC)
Product #C-PC-07327
Coconut
Product #UN0332
Ivory
Product #UN1704
Yellow
Product #CNY12055
Citrus
Product #UN1690
Canary Yellow
Product #UN1700
Banana
Product #UN1693
Sunflower Yellow
Product #UN1625
Jasmine
Product #UN1696
Marigold
Product #UN1702
Orange
Product #AB23620333
Orange LS (Nylon Non-HS)
Product #C-NY-12047
Orange (for PC)
Product #C-PC-07154
Nectarine
Product #UN2252
Seville Orange
Product #UN2239
Flame Red
Product #UN3820
Red (for PC)
Product #C-PC-07152
Cardinal Red
Product #UN3861
Rocket Red
Product #UN3872
Cherry Red
Product #UN3788
Rose Pink
Product #UN3364
Purple
Product #UN55094
Powder Blue
Product #UN5009
Cornflower Blue
Product #UN55162
Sky Blue
Product #UUN5001
Mid Blue
Product #UN5011
Royal Blue
Product #UN5027
Midnight Blue
Product #UN55160
Springtime
Product #UN66072
Fresh Green
Product #UN66083
Fern Green
Product #UN66070
Leaf Green
Product #UN6994
Racing Green
Product #UN66075
Cloud Grey
Product #UN77000
Soft Grey
Product #UN7759
Pebble
Product #UN7999
Dove Grey
Product #UN7378
Ash Grey
Product #UN7021
Mid Grey
Product #UN7053
Grey (Medical)
Product #EMD-887756
Dusk
Product #UN77013
Mink
Product #UN77007
Moonstone
Product #UN7996
Graphite
Product #UN7994
Mushroom
Product #UN8021
Honey Beige
Product #UN88723
Beige
Product #UN88729
Deep Black
Product #UN0055
Silver
Product #UN0701
Copper
Product #UN0567
Transparent Amber
Product #UN2034TR
Transparent Red
Product #UN3012TR
Transparent Blue
Product #UN5016TR
Transparent Green
Product #UN6881TR
Transparent Grey
Product #UN7903TR
Silicone Rubber
Cool Grey
Product #GSDI 96777
Red
Product #GSDI 346
Transparent Red
Product #GSDI 354
Purple
Product #GSDI / Violet 77632
Blue Tint
Product #GSDI Blue 292
Blue
Product #GSDI 278
Green
Product #GSDI 176
Grey
Product #GSDI 122
Silcopas Grey
Product #GSDI 425C
Black
Product #GSDI 220
White
Product #GSDI 056
Black
ABS
Acetal
Nylon
PC
PP
PPE/PS
PPSU
Natural
ABS
Acetal
LDPE
Nylon
PEEK
PEI
PP
PSU
UHMW
White
Acetal
HDPE
PET
PS
PTFE
Clear / Transparent
PC
PMMA (Acrylic)
Gray
CPVC
PVC
Light Blue
Nylon
Black
ABS-Like
Digital Black
Nylon
Green
ABS-Like
Clear / Transparent
ABS-Like
Digital Clear
PC-Like
PP-Like
White
Digital White
Nylon
PP-Like
