Direct Metal Laser Sintering
Direct metal laser sintering (DMLS) is an industrial 3D printing process that builds fully functional metal prototypes and production parts in 7 days or less. A range of metals produce final parts that can be used for end-use applications.
When the build finishes, an initial brushing is manually administered to parts to remove a majority of loose powder, followed by the appropriate heat-treat cycle while still fixtured in the support systems to relieve any stresses. Parts are removed from the platform and support structures are removed from the parts, then finished with any needed bead blasting and deburring. Final DMLS parts are near 100 percent dense.
1 to 50+ parts
Shipped in 1 to 7 days
Parts starting at $95
Best for:
  • prototyping in production-grade materials
  • functional, end-use parts
  • reducing metal components in an assembly
DMLS Materials
We offer numerous 3D printing material options that are regularly updated to meet prototyping and master fabrication needs. Our DMLS selection includes aluminum, cobalt chrome, Inconel, stainless steel, and titanium.
VIEW MATERIALS
Design Guidelines
Our basic guidelines for DMLS include important design considerations to help improve part manufacturability, enhance cosmetic appearance, and reduce overall production time.
VIEW GUIDELINES
a metal 3D printing technician removes support structures from a DMLS part
GET A QUOTE
