Multi Jet Fusion
Multi Jet Fusion is an industrial 3D printing process that produces functional nylon prototypes and end-use production parts in as fast as 1 day. Final parts exhibit quality surface finishes, fine feature resolution, and ‬more consistent mechanical properties when compared to processes like selective laser sintering.
How Multi Jet Fusion Works
Multi Jet Fusion uses an inkjet array to selectively apply fusing and detailing agents across a bed of nylon powder, which are then fused by heating elements into a solid layer. After each layer, powder is distributed on top of the bed and the process repeats until the part is complete.
When the build finishes, the entire powder bed with the encapsulated parts is moved to a processing station where a majority of the loose powder is removed by an integrated vacuum. Parts are then bead blasted to remove any of the remaining residual powder before ultimately reaching the finishing department where they are dyed black to improve cosmetic appearance.
1 to 50+ parts
Shipped in 1 to 7 days
Parts starting at $95
Best for:
  • parts requiring consistent isotropic mechanical properties
  • functional prototypes and end-use parts
  • complex and organic geometries with fine features
Multi Jet Fusion Materials
We offer a commercial-grade unfilled Nylon 12 material that creates durable parts with consistent isotropic mechanical properties.
VIEW MATERIALS
Design Guidelines
Design guidelines for Multi Jet Fusion include important design considerations to ensure optimal part quality, enhance cosmetics, and reduce production time and costs.
VIEW GUIDELINES
a metal 3D printing technician removes support structures from a DMLS part
GET A QUOTE
