Selective Laser Sintering
Selective laser sintering (SLS) is an industrial 3D printing process that produces accurate prototypes and functional production parts in as fast as 1 day. Multiple nylon-based materials are available, which create highly durable final parts.
How Does Selective Laser Sintering Work?
The SLS machine begins sintering each layer of part geometry into a heated bed of nylon-based powder. After each layer is fused, a roller moves across the bed to distribute the next layer of powder. The process is repeated layer by layer until the build is complete.
When the build finishes, the entire powder bed with the encapsulated parts is moved into a breakout station, where it is raised up, and parts are broken out of the bed. An initial brushing is manually administered to remove a majority of loose powder. Parts are then bead blasted to remove any of the remaining residual powder before ultimately reaching the finishing department.
1 to 50+ parts
Shipped in 1 to 7 days
Parts starting at $95
Best for:
  • durable prototypes
  • functional, end-use parts
  • complex geometries
SLS Materials
We offer numerous 3D printing material options that are regularly updated to meet prototyping and master fabrication needs. Four different types of nylon materials are available in SLS for different levels of stiffness and ductility.
VIEW MATERIALS
Design Guidelines
Our basic guidelines for SLS include important design considerations to help improve part manufacturability, enhance cosmetic appearance, and reduce overall production time.
VIEW GUIDELINES
a metal 3D printing technician removes support structures from a DMLS part
GET A QUOTE
