CNC Milling
Our CNC milling process produces custom prototypes and end-use production parts in as fast as 1 day. We use 3-axis milling and 5-axis indexed milling processes to manufacture parts from more than 30 engineering-grade plastics and metals.
How Does CNC Milling Work?
We have multiple toolsets based on efficient cutters for a particular plastic or metal material. The machine then rapidly mills parts out of the block in a subtractive manufacturing process that uses either 3- or 5-axis milling.
Machined plastic parts are left as-milled, which typically means they show visible tool marks. Some metal parts allow more finishing choices. When the run is complete and your required surface finish is applied, parts are boxed and shipped shortly thereafter.
CNC Machining Icon
1 to 200+ parts
Shipped in 1 to 3 days
Parts starting at $65
Best for:
  • functional prototypes
  • jigs and fixtures
  • end-use components in lower volumes
Milling Materials
We stock more than 30 production-grade plastic and metal materials that are suitable for various part applications and industries. Materials range from plastics like ABS, polycarbonate, nylon, and PEEK to aluminum, stainless steel, magnesium, and copper.
VIEW MATERIALS
Design Guidelines
Our basic guidelines for CNC milling include important design considerations to help improve part manufacturability, enhance cosmetic appearance, and reduce overall production time.
VIEW GUIDELINES
3D CAD model
Free interactive design analysis within hours
GET A QUOTE
