CNC Turning
Our CNC turning process produces custom prototypes and end-use production parts in as fast as 1 day. We use a CNC lathe with live tooling so features like axial and radial holes, flats, grooves, and slots can be machined.
How Does CNC Turning Work?
During the CNC turning process, a metal rod is rotated while a cutting tool is held against the stock to remove material and create final parts. The lathe rapidly machines your parts in a subtractive turning process with additional live tooling. Outside diameter (OD) and inside diameter (ID) threading is also available.
Turned parts can then be left as-machined, with visible tool marks, or bead blasted. When the run is complete, parts are inspected, boxed and shipped shortly thereafter.
CNC Machining Icon
1 to 200+ parts
Shipped in 1 to 3 days
Parts starting at $65
Best for:
  • functional prototypes and end-use parts
  • parts with cylindrical features
  • parts with axial and radial holes, flats, grooves, and shots
Turning Materials
We stock a range of metal materials that are suitable for various part applications and industries. Choose from aluminum, brass, low carbon steel, stainless steel, steel alloy, and titanium for turned parts.
VIEW MATERIALS
Design Guidelines
Our basic guidelines for CNC turning include important design considerations to help improve part manufacturability, enhance cosmetic appearance, and reduce overall production time.
VIEW GUIDELINES
applications engineer examines a part
Free interactive design analysis within hours
GET A QUOTE
